100mbps Bonding.....
Hi all, i have tested RB433AH (800mhz) with Cm9 en Turbo Mode, it gives 69-70 mbps send or receive, both 35mbps. I think is great performance but i need 100 mbps, any body knows if i put 2 RB433AH both with cm9 and turbo mode, in each end one RB1000 (2 total) to make bonding with the 2 RB433, can i make a link with 100mbps?, the question because the RB 1000 is expensive and i can’t expend money if doesn’t work.
Thanks A lot.
And Regards from Colombia S.A
Dimas
sure it will. or you can use 1 rb 433ah each side with 2 cards , make a eoip or wds and bond them.
i tryed this but the proccessor shows 100% and it gives 70 or 80 mbps in the bonded interface, so i tryed nstreme 2 to get 70 mbps in full duplex, but only got 55 mbps send, 15 mbps receive simultneously.
did u disabled connection tracking ?
