Hi all, I have a issue with a 2011UiAS that does not want to go faster then 100Mbit.
I know it's a oldie and it might need replacement, but the almost exact 100Mbit makes me wonder if i did not screw up the config.
Background:
When the 2011UiAS was just out, i helped a friend to install it for his hotel. He has 2 VDSL lines incoming.
Back then the lines were 50Mbit each, and the router performed well. Its doing Dual Wan via PCC. masquerading for the 2 lines, has minimal firewall rules and about 30 simple queues.
Current:
Lines have been upgraded to 200Mbit each. Same Dual Wan via PCC and same simple queues.
(there were some other rules related to hotspot and a vlan but those are disabled to see if it had any influence)
When i do a speedtest, the speed always limits around 95-99Mbits.
All ports report 1Gb. Connected directly to the provider routers it brings full line speed of around 190-195.
When i look in a export of the config, i see this and wonder if its related ? (the ports still say they negotiate on 1Gb, so i doubt it but want to be sure)
It did look strange to me as port 1-5 should be the gigabits and ports 6-10 the 100Mbit ?
set [ find default-name=ether1 ] name=ether1 speed=100Mbps
set [ find default-name=ether2 ] name=ether2 speed=100Mbps
set [ find default-name=ether3 ] name=ether3 speed=100Mbps
set [ find default-name=ether4 ] name=ether4 speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full disabled=yes
set [ find default-name=ether7 ] advertise=
set [ find default-name=ether8 ] advertise=
set [ find default-name=ether9 ] advertise=
set [ find default-name=ether10 ] advertise=
Also i could not find where i would have set ports 1-5 to 100Mbps in the Winbox Gui... All ports have all options in advertise enabled.
As the two WAN's (3-4) & the lanport (2) show 1Gb negotiation so it has me confused.
Any clue if its my config or its just on the limits of the hardware ?
As a sidenote, its still running 6.44, i am 3500Km away so i did not dare to do an update.
Greetings and thanks
Steve
