I have a RB450G router with a 300Mbps/300Mbps internet connection. In other place I have a 100Mbps/10Mbps internet connection and I want to join them with a VPN.
I read in the IPSec wiki that it depend on which hardware I use I could get different results.
If I put the RB 450G and a RB750UP r2, could I get a 100Mbps VPN?
I use two hAP with IPSec tunnel. Since it lacks crypto-offload, it maxes out about ~30Mbps
I suggest IPSec with some board with crypto-offload in hardware. OpenVPN support on RouterOS isn’t that great (and IPSec is much better for permanent/static tunnels)
If security is not a concern, you could use an plain GRE/IP-IP tunnel.
