we are currrently testing CCR2116-12G-4S+ with 4x 10G-LR SFP connecting to a Juniper QFX5120-32C through 4x10G-LR breakout.
We verified the Juniper ports to be correctly working with switches and routers from other vendors.
However, the CCR doesn’t work with either of them in a stable manner. We tried 7.16b2 and 7.15.1.
We tried Fiberstore and Flexoptix 10G-LR optics, which work fine in other devices like Juniper QFX5120-48Y.
The Flexoptix are coded to Mikrotik S+31DLC10D.
In /interface/ethernet/monitor sfp-sfpplus we observe the SFP disappearing about every 20-40s, triggering RX LOS on the other side:
Jun 21 16:30:08 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low alarm cleared
Jun 21 16:30:08 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low warning cleared
Jun 21 16:30:08 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx loss cleared
Jun 21 16:30:46 hostname mib2d[11204]: SNMP_TRAP_LINK_UP: ifIndex 625, ifAdminStatus up(1), ifOperStatus up(1), ifName xe-0/0/6:2
Jun 21 16:30:47 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low alarm set
Jun 21 16:30:47 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low warning set
Jun 21 16:30:50 hostname mib2d[11204]: SNMP_TRAP_LINK_DOWN: ifIndex 625, ifAdminStatus up(1), ifOperStatus down(2), ifName xe-0/0/6:2
Jun 21 16:30:51 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low alarm cleared
Jun 21 16:30:51 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low warning cleared
Jun 21 16:30:51 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx loss cleared
Jun 21 16:31:09 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low alarm set
Jun 21 16:31:09 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low warning set
Jun 21 16:31:28 hostname mib2d[11204]: SNMP_TRAP_LINK_UP: ifIndex 625, ifAdminStatus up(1), ifOperStatus up(1), ifName xe-0/0/6:2
Jun 21 16:31:32 hostname mib2d[11204]: SNMP_TRAP_LINK_DOWN: ifIndex 625, ifAdminStatus up(1), ifOperStatus down(2), ifName xe-0/0/6:2
Jun 21 16:31:33 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low alarm cleared
Jun 21 16:31:33 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low warning cleared
Jun 21 16:31:33 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx loss cleared
Jun 21 16:32:10 hostname mib2d[11204]: SNMP_TRAP_LINK_UP: ifIndex 625, ifAdminStatus up(1), ifOperStatus up(1), ifName xe-0/0/6:2
Jun 21 16:32:11 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low alarm set
Jun 21 16:32:11 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low warning set
Jun 21 16:32:14 hostname mib2d[11204]: SNMP_TRAP_LINK_DOWN: ifIndex 625, ifAdminStatus up(1), ifOperStatus down(2), ifName xe-0/0/6:2
Jun 21 16:32:15 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low alarm cleared
Jun 21 16:32:15 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low warning cleared
Jun 21 16:32:15 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx loss cleared
Jun 21 16:32:52 hostname mib2d[11204]: SNMP_TRAP_LINK_UP: ifIndex 625, ifAdminStatus up(1), ifOperStatus up(1), ifName xe-0/0/6:2
Jun 21 16:32:53 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low alarm set
Jun 21 16:32:53 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low warning set
Jun 21 16:32:56 hostname mib2d[11204]: SNMP_TRAP_LINK_DOWN: ifIndex 625, ifAdminStatus up(1), ifOperStatus down(2), ifName xe-0/0/6:2
Jun 21 16:33:01 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low alarm cleared
Jun 21 16:33:01 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx power low warning cleared
Jun 21 16:33:01 hostname fpc0 qsfp-0/0/6 Chan# 2: Rx loss cleared
Routerboard firmware has been upgraded, config is reset and in default settings, also device has been hard-rebooted by removing power.
Any idea what could cause the issue?
Kind regards,
Frank
