10g solarflare & mellanox Nics Supported??
hi,
does anyone know if some of these sfp+ nics are supported??
solarflare sfn7122
solarflare sfn5122
mellanox cx312a (connectx3)
Directly from RouterOS x86 or with CHR?
CHR with passthrough these nics !
some help with this??
so no one uses mellanox or solarflare??? :frowning:
i can confirm that in router os 7.3 and after, sfn7122 works!
solved
OK :slight_smile:
thanks for reporting spam eliminated
Hello
I have used Mellanox and is supported
Hi yes they work.. directly on router os v7..
i can also confirm Mellanox 40gbps works.. and mellanox 100GBps card works but you have to go into nvidia to downlaod latest firmware drivers.. and use windows machine to flash new firmware drivers and change infiniband mode to Ethernet mode on configuration of the card.. only after changing to ethernet mode it will work and show up on routerOS v7
