10Gb on RB2011 - bad idea?
TL,DR: 10Gb SFF on a RB2011 - yay or nay?
Hello!
I’m setting up a Dell R710 running a bunch of VMs for various uses (Plex, NAS, a high sample rate ADC for SDR, etc) and it has four 1Gb network ports. I’m expecting a handful of PCs, some smart phones, and consoles as the likely clients. The internet uplink is 100/40, so that’s not likely to be a problem for bandwidth. The ADC can sample to around 80MS/s@16bit (over 1Gb/s - it saturates a USB3 connection if set up poorly). The rest I assume is fine on GbE - everything else in the house is on Gb ports (except the printer… 100Mb is fine for that).
Rather than connect multiple ports to the router and manually splitting the I/O among VMs, I was wondering the usefulness of connecting the server via 10Gb SFF (with a matching card in the server). The two would be located close together (in the same rack, most likely) so distance isn’t a problem.
I’m not planning on running a firewall or VPN on the RB2011 (it’ll be on the R710) but do want to have a script that allows internet access and a minimal firewall if the server is down (eg. default route via 710, if 710 is down then route directly). I’ll worry about this part later, once I get the 710 working. The 2011 will handle DHCP, and be the router for the network (port forwarding, hairpin routing, etc).
Great idea. Shame the RB2011 only has SFP and not SFP+ so won’t do a 10Gb connection.
Im not sure why this question gets posted here 1:1, after it was already answered on reddit:
https://www.reddit.com/r/mikrotik/comments/ayzto8/10gb_on_rb2011_bad_idea/
RB2011 → Only SFP → no 10Gb/s
Go to the product page, take a look at block diagram, you will be able to see that there are only 1,5Gbps line in connections to CPU
https://mikrotik.com/product/RB2011iLS-IN#fndtn-downloads
RB2011 with SFP+ = RB4011
It is a spamming account. Posts get edited and filled with spam links after a while.
Thanks for the clarification. I heard about this but never seen it tho.
