1100AH remove quickset
I updated 1100ah to v6 and installed all packages
It grabbed quickset which clearly is not meant for it as it has put addresses in the fields that do not apply.
It has occurred to me to take it out in case of accidental clicking or something.
It also occurred to me there may be other modules in that upgrade that are not meant for the 1100AH.
What packages should i remove from the 1100AH when i installed all packages? (how do i do it safely? Router is in production)
Go to system - packages, mark them for uninstall and reboot.
ok straight forward enough
Anyone know the 1100AH well enough to recommend which ones are not compatible?
All are compatible. Only wirelesses is useless as device does not have any wifi.
cool
i didnt see an option to remove quickset in system/packages
It is not separate package. It can’t be removed. Just do not use it and it will not have any influence.
