At one of our sites we have 2 1100AHx2 running as we need the extra ports and rather than go back to L2 with a switch I put another RB in there and set up a /30 between them both.
Performance, however, has taken a hit. If I bandwidth test from 1 RB to the other UDP I get close to 1Gbit/s however if TCP it’s more like 200Mbit/s. I wasn’t expecting TCP to be as high as UDP but to only achieve a fifth of the throughput doesn’t seem right.
The two RBs are connected with a CAT5 patch cable which I’m going to swap out today for a shielded CAT6, but if it was electrical problems surely the UDP wouldn’t achieve such a high throughput.
I’m a bit confused here…any ideas?
Adyb
