112 or 133
Hey guys,
want to know what will you go for, because on the paper 133 looks better more interfaces more RAM more storage (NAND), which do you think is better in performance?
Can 133 handle power requirement , if we install three high power cards?
regards
they use the same CPU, so the only difference is the amount of memory and interfaces. RB133 is cheaper and better
133 with out question. more interfaces more m-pci more ram, better power supply…same price
