128+128=256???
could be have 128+128=256
pcc no any other can??? bonde???
yesss, bonding in RR mode =) but only on low-latency links, and only if you control both sides of the link
peleas explaen more about low-latency and control both sides
so the bonding better than pcc !!!
if those links are between your routers - you may bond them. if you use RR mode on high-latency links, packet reordering may occur. it’s bad =)
PCC and bonding are for different goals. bonding has nothing to do with load balancing
