we have a 2.5km link with a OmniTIK and a SXT (5GHz, both chains, long guard interval). Everything is working well, signal strenght is -69db. LOS is ok, fresnel is not 100% free (there are trees).
Since yesterday it’s snowing and the signal is -81db now … is it normal that the signal will decrease 12dB just because of snow?
If you think about it, weather radar works by getting reflections from rain and snow. The heavier it is the more reflection and absorption there is. So you have to expect some signal loss from precipitation.
Also as rodolfo points out, unlike rain, snow accumulates, on your antennas, on the trees that are in your line of sight, … I’m sure that there are tables for this somewhere, in a radio engineering handbook or the like, that will give you the attenuation factor for a km of forest (brush, light forest, heavy forest, snow covered forest, …).
I had a significant storm in my area and I lost just 1-2dBm BUT the snow blocked a lot of noise and my SNR gain 10dBm+ on many of my sectors!
My shortest link is 1/3 mile (2 nanobridges ptp) and it got 4dBm improvement in signal
My average link is about 1.5 miles. Performance on this 1ft+ snowfall day was excellent.
Snow itself will not attenuate the signal for the frequencies beings used. My guess is snow collecting on the trees is interfering with your signal. I bet you could correlate a continual drop in signal as snow depths increased.
Also, have you been able to look at the antenna’s to ensure no buildup of ice/snow?
