I’m starting up soon, within the next couple of weeks. I’ve got a 6.6 mile shot to my tower, planning on a 29dBi 5.8GHz grid on each end and R52s. From there, I’ll have a 29dBi 5.8 going 3 miles to a tower with 2 ft size limitations, so I can only use a 26dBi. This is the part I question.
From there, the plan is a 26dBi/R52 5.8GHz shot 13 miles, open space, perfect line of site and fresnel is clean, with a 29dBi/R52 on the other end. Is the 26dBi antenna going to be enough for this distance?
Online calculators show it works fine, however they have been overly optimistic with my other p2p shots. I don’ t see any reason it wouldn’t work, but the longest shot I have experience with is 5 miles. I just wanted to ask those that have done it before I get money tied up.
I’d say it would be unreliable at that distance.
You can get a 29dbi solid dish that is 2 foot and a 32dbi is 3 foot.
If you’re running 3’ of lmr400 you should have a good link with about a 11 db fade margin.
Aug
F/B Ratio dB ≥25
VSWR ≤1.5
Input Impedance-Ω 50
Polarization Vertical or Horizontal
Max Power -W 100
Connector N-Type Female
Dimension-m 0.4x0.6
Weight kg 2.4
Yes I’ll add to this that your link budget is more that adaquate.
I have shot a 5.8Ghz 28km link with 2 27dbi dish’s and 2 100mw cards.
There was more than enough signal , 48 mb connection rate, although throughput was poor.
I have since divided the link in 2 and more than doubled the throughput.
On one end of each link I have an original 27dbi grid on the other end only a 17 dbi flat panel ant.
Each of these links is +16 km ! (the divided original shot takes a differnt path)
Throughput and reliability have been rock solid over 2 years now.
They connect at 108 mb “turbo” without fail
In storm conditions it slows down to 96 mb never lower.
The larger dish not only improves transmissin strength but reception sensitivity.
I have been able to connect and surf off a 24 dbi ant on a 24m tower in 2.4ghz with a 18mw laptop card with no external ant at over 6km ! again the the dishes sensitvity is the key.
I have shot a 5.8Ghz 18mile link with 2 27dbi dish’s and 2 100mw cards.
There was more than enough signal , 48 mb connection rate, although throughput was poor because of long ack.
Each of these links is +10 mile ! (the divided original shot takes a differnt path)
I have been able to connect and surf off a 24 dbi ant on a 60foot tower in 2.4ghz with a 18mw laptop card with no external ant at over 4 miles ! Again the the dishes sensitvity is the key.
Thanks for the input guys, the yays and the nays. I think I’ll probably swap the R52 for XR5 for the long shot just for headroom. The extra power might make it easier when we start alignment.
You can get much more precise information by using some link modeling software, that will actually take topography in to account - I use Radio Mobile, which is free, flexable, and highly useful.
