Is there a 133 indoor case? if so, where can we get it from (reasonably, from a normal reseller).
i dont see any anywhere and this is really holding up my deployment…
I second this question.
I am going to try a 532 case. If I have to drill a hole for the power I will. If I have to snap off some posts and put in some sticky posts, I will do that too. If I have to dremel the outside ethernet port I guess I can do that too.
I have seen 133 cases in cznet.cz
wisp-router.com in US has them listed on backorder for 3 weeks.
