133 stability issues
hi,
would like to know if any one has tried the following scenarios with stability:
WLM54AG (BH) & XR2 (distribution) on 133
WLM54AG (BH) & SR2 (distribution) on 133
Also, I am facing a very strange problem on 133 board with the second scenario on table test when i scan SR2 card for wireless link the system automatically reboots and on this boot it doesn’t shows SR2, I shutdown the router remove the card and re-insert it , it is back on but when I scan same problem. I tried replacing SR2 cards but no success, i tried replacing WLM54AG no success, i tried replacing 133 little success I got the scan then I rebooted and the ghost of Christmas past returns and enters the fresh board also.
Has any one else faced this kind of problem, can you share your view and solution for this.
How much power are you running to the board and how far are you running the power line? If the power feed is a long run you may have to much loss and be ubnder powering the board which would cause the cards to disappear/reappear at random.
hi this was just a table test with 2pcs 7ft patch cord CAT6 of systimax (one for switch and other for POE) and 18v 1.1 A POE adapter
100% right
try direct power jack
i ues 2 xr2 with version 2.9.43 every thing is stable
Yes, it looks like a power issue. this is common with Ubiquiti cards
