we are using 133 boards with 50mtr CAT6 cable and 18v 1.1A POE getting frequent RTOs and latency , is any one facing this probelm, by using of 24v 1.0A adapter help us out. please let me know.
Its better to use a STP Cat5 instead of UTP Cat6 as the STP comes with a metal jacket which when grounded cancels a lot of noise . Also check the guage of the wire.
A lot of companies say the cable is 24AWG but actually they are worst than 26AWG.
BYW MKSB : I am also from india and hopefully we can share a lot.
you can add me at skype : xserver2007 or yahoo : sumankdash {at} yahoo {DOT} com
if this question for me!! sure i m using 568A standard
do you think it will work when you just doing a colour matching game???
for me i dont care about AWG number coz its not accurate as you think
try and try then try then you will make it work somehow
Well… First of all it was for the poster who is getting High Latency and ping Losses. Don’t take everything as granted .
And for color matching games try to use without following the standard and you will get the results. if not better then the worst pings and data loss especially when you are running high length of cable.
And as per your quote i would like to mention you that there are perfect cable that are 24AWG and 22AWG unless and until you are using crappy or borrowed cables from local store.
If you try industrial CAT6 then your view will change. Try using LAPP Cables and comment back.
When when i was new to networking i tried 50 ft non standard and kept scratching my head for continuous 8 hrs wasting around 40 RJ45 Jacks and the 50 ft cable itself.
The Poster needs to use around 18-20V switching Power supply instead of linear power supply.
I am sure that it will work. And as Taloot said the best regulated available is the laptop chargers. Temporarily use it and see whether it solves your problem or not.
Well… Now i am 27 and i started at 18 so still i need 1 more yr. to catch you.
When are you going to retire or can you go for a 1 yr. vacation ?
