13km 5ghz-turbo link
I have set up 13km 5ghz-turbo wireless link with the following config:
dual polarized antena jrc-24 duplex
 0  R name="100" mtu=1500 mac-address=XX:XX:XX:XX:XX:XX arp=enabled interface-type=Atheros AR5413 mode=bridge ssid="XXXX" frequency=5260 band=5ghz-turbo
      scan-list=default antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes
      default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=yes
 1  R name="350" mtu=1500 mac-address=XX:XX:XX:XX:XX:XX arp=enabled interface-type=Atheros AR5413 mode=bridge ssid="XXXXXx2" frequency=5600
      band=5ghz-turbo scan-list=default antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes
      default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=yes
With this settings I’ve got signal -71 on wireless card “100” and -67 on wireless card “350” with nstreme, polling and csma disabled. MT 3.22
The problem is that the wireless cards are connecting only in 36mbps*2 and I can’t get more than 80mbps (bandwidth test) in one way with bonding…
signal is too low and 80mbps in bonding is normal for 362. I had 40-50mbps with 362. Use cards with more power or change the antennas. With a -50 -60 you should have at least 120mbps.
thank you for the reply.
at non-turbo mode the signal is above -65
what card will i have to use for this link?
the antenas are brand new and I don’t want to change them…
