I HAVE TWO RB133 WITH UBIQUITY XR5 CARDS AND 26 DB GRID ANTENNAS.
I HAVE SIAGANLS BETWEEN -55 AND -60
TX/RX CCQ BETWEEN 45 AND 60%
SIGNAL TO NOISE BETWEEN 20 AN 25
I HAVE DISCONNECTIONS OF ABOUT 30 MIN
I AM USING 5GHZ MODE
CAN ANYBODY TELL ME WHAT CAN I DO, AND ALSO TELL ME IF CAN I USE THE OTHER MODES 5GHZ-TURBO,5GHZ-10MHZ,5GHZ-5MHZ. I HAVE NEVER USE THIS MODES
THANKS FOR THE HELP
I LOWERED THE POWER OF THE CARDS END THE QUALITY CAME UP AND ITS IS WORKING BETTER. I HAVENT HAD ANY DISCONNECTION SINCE.
CAN ANY BODY EXPLAIN TO ME WHAT ARE THE BENEFFITS OF USING THE OTHER MODES IN 5.8GHZ
5.8 GHZ TURBO, 5.8GHZ-10MHZ,5.8GHZ,5MHZ?
turbo is 40mhz channel, double the bandwidth, weaker signal.
10mhz is half the bandwidth but stronger signal.
5mhz is quarter bandwidth, but stronger signal than 10mhz.
THANKS FOR THE HRLP
I HAVE THE LINK WORKING WITH TX/RXCCQ OVER 90%
SURFING AND DOWNLOADS ARE VERY GOOD BUT, MEN MESSENGER DOS NOT WORK, I HAVE BOTH RADIOS IN BRIDGE MODE. ANY IDEA WHAT COULD BE THE PROBLEM?
