16 port Gigabit switch with DC input?
Hi guys,
I would like to know if anyone know an inexpensive unmanaged Gigabit switch 16 ports with DC input (12V, 24V or 48V)??
Unfortunately CRS is out of my budget cause I need hundreds of them.
Thanks,
Could you give us more information about the applications you would use it for ? we could make something like that. Let us know the features you would be interested in, and the possible usage scenarios
Hi normis,
This is for residential buildings, we usually deploy some, 6-7, RB750UP (or ToughSwitch PRO) and then install one unmanaged FastEthernet 16 ports switch (powered using POE and then use a passive adapter to separate Ethernet and DC power) per floor, and then a RB951Ui-2HnD on each apartment (we want to use RB951G-2HnD now cause it’s Gigabit). So, we install a lot of switches and RB951.
Thanks,
