good day
I have a link with 300 mbps approx. but I cannot get the perfect switch with 16 ports at least which is certifed my requirements
good day
You need a switch or a router?
yes sir I need a switch with 16 ports at least … the main point is (16 ports)
If you can’t find a switch that suites you on this page, then you’ll have to look at other vendors.
thank you
what is your advice ? which is model more suitable for me?
No idea about your requirements. E.g. those 16 ports, should they be copper RJ45 or SFP? Do you want to run ROS or SwOS? If ROS, any requirements about L3 capacity?
