17.1 - 17.3 Ghz
Does anybody know if there is a way to use 17.1 - 17.3 Ghz space with an MT based device?
Thanks,
Ricky
Yes you can use a upconverter to a standard 5 ghz card.
I will try this to but for the 10 ghz range .
But i thing you have to built all the gear by your self or check this site they can help you out http://www.procom-dk.com/ they built feeders and parabolics osv..
//Rickard
would you like to post additional details of a commercial transverter available. I am looking for a 802.11 transverter for 6-10 Ghz .
can anybosy tell me for 700MHz up convertor manufactrer or site
thanks in advance .,..
over 5ghz so 10ghz and more it is hard to buil long-stable link, becouse of wether, temp - can not allowed to use it… With frequency distance is lower.
