If I try to either convert existing lease to static OR create brand new entry (it does not matter if MAC is real or Private WiFi Address) the behaviour is always the same
In DHCP I see: offer, bound, declined
dhcp-vlan1 (defcon) client 2E:CE:6B:FC:93:A6 declines IP address 192.168.88.45
The only way is to leave the units as dynamic
But even the lease on DHCP is configured to 3 days, the units get new address every 24 hours
If using Microsoft DHCP server (obviously NOT on the same network!), I do not have any such issue with same devices
Well, it is called real life. One does not have luxury of clean router setup, and even if it works, it helps zero, because I need it working in the existing setup
Ok, with such an attitude I guess you are not seriously trying to resolve the issue then. If you are serious, be nice towards people who are trying to help you and read up on https://debug.guide/.
Debugging like that guide specifies is part of real life for technicians too!
The principle to successfully debug is to remain unbiased. Therefore, do not immediately blame, for example, MikroTik. If the same devices work without issues in another network with a different DHCP server, the DHCP server may not necessarily be the cause. There are many other factors to consider, such as the differences in network configuration and clients.
This is not a RoS Issue … this is an Apple Setting that you must change if you want the Apple device to get a static IP
I will use an iPhone as an example:
On the iPhone Go to Settings and Wi-Fi THEN touch the i that is encircled turn off ==>> Private Wi-Fi Address
This will enable your iPhone to get a static addess from your RoS DHCP server.
I’ve had issues like this with iOS devices in the past. I’m not familiar with the iOS network stack, but suspect that iOS devices maintain some kind of internal list of recent DHCP leases and seem to think that leases are still bound when they are not. It could be that your Microsoft DHCP server works as it’s presumably serving a different IP range.
IIRC my issues seemed to be around specific addresses; forcing a different, previously unused address solved the issue. After a period (eg a day) , the device started to then accept the original address.
Does your issue occur with every address in the DHCP range in question?
Yes I did read your OP.
2 additional things that you can try
After turning off Private Wi-Fi Address turn off WiFi on your iPhone
In RoS DHCP Leases delete the entry for your iphone
Now turn on your iPhone Wi-Fi
Look for the dynamic lease to come back in your RoS DHCP Leases screen
Once you see the lease NOW make it static and ASSIGN the IP Address that you want it to have
Go Back to your iPhone and turn off the Wi-Fi and after 5 seconds turn the Wi-Fi back on … does this work for you ?
No, sorry, does NOT work (with any iPhone in the house)
Each & every one fails the exactly same (as per first post)
Dynamic works, Static never allows connection (Offer/Bound/Declined)
It does happen with ANY address (ie one that could have NEVER previously be issued/used like 192.168.88.250)
Ofcourse unless one knows easy way to get logs from iOS device itself, I have no idea what is going on inside there
And the declined comes definitely from iOS
