You’ll have to forgive me if this has already been answered as I haven’t found anything similar in searching… Has anyone else experienced 1Gb SFPs failing to properly link after fiber bounces when placed in SFP+ cages? Docs indicate the SPF+ cage supports both 1.25G and 10G SPFs, but I can repeatably lockup the link on Mikrotik routers with a simple fiber unplug/replug (CCR1009-8G-1S-1S+ and CCR1036-8G-2S+ tested). Hardware does not seem to make any difference a the port must be disabled/enabled in ROS for the port to become usable again.
Tested with CCR1009-8G-1S-1S+ and CCR1036-8G-2S+ routers utilizing Mikrotik, Planet, and Finistar 1.25Gb 850nm SFPs in various combinations and ports, as well as a Planet IGS-1020MT as an intermediary switch. Tested over multiple ROS 6.34.3 - 6.41.4 with FW 3.33 ad 3.41.
- CCR1036 SPF+ cage (either of the 2), 1Gb SFP module connected to 1Gb SPF in Planet switch with 1m fiber patch - links as expected, RX -5db to -7db on each side depending on vendor SFP module, passes traffic normally.
- Pull fiber patch and replug - Planet switch still shows RX -5db but will not link, CCR10xx shows link in ROS and on front LED, but SPF reports either -5db or -27db ( or -40db, no RX equivalent depending on SFP sensitivity) at different times, unable to characterize why it is sometimes one or the other.
- Pull SFP module out of CCR10xx SFP+ cage and reseat or replace with different SPF module - Planet switch shows -5db but will not link, CCR10xx shows link but still dead.
- Reboot Planet switch, reseat/replace hardware - no change in link status.
- Disable/enable the sfp-sfpplus interface in ROS - fiber links on both ends and passes traffic normally.
- Using regular SFP slot in CCR1009-8G-1S-1S+ or CCR1009-7G-1C-PC connected with same SFPs and fiber to the Planet switch - no issues removing/replugging fiber patch, links as expected every time.
Also, 1Gb SFP in CCR10xx SFP+ cage, will not link under any circumstance to a SFP in a 1Gb SFP cage of another CCR10xx.
Seems like an interface reset issue with SPF+ cages on Mikrotik routers. Anyone see this or is there a FAQ somewhere that explains this?
