Some ISPs are looking at testing 10gb ftth in 2019/2020. Right now, I’ve a 1gb connex., which is working great with my CCR1009-7G-1C-PC.
But in the futur, I will need a 10gb port. Even 2 (1 wan, 1 lan). So, the CCR1009-7G-1C-1S+PC looked good with the sfp+ cage, until I notice that It’s the only 10gb port. I guess I can team some other eth port after that, but lacp is not a perfect solution.
Is there a futur product, mid range like CCR1009 (and passively cooled if possible), planned with 2 10gb ports ?
But in this case, I still need 2 10gb port on the router, right ?
“Switch goes into router” => So in the “wan” part of the routeur, need 10gb here.
“routeur back to switch for output via LAN port” another 10gb needed here on the “lan” router side.
No ?
Because I already do this, but with 1gb link, at the moment (ONT => Switch => Router(WAN) => Routeur(LAN) => Switch. I play with VLAN to isolate the ONT=> WAN traffic on the switch)
Ah yes ok, I see it now. Thx. I don’t think It would be a problem for residential usage either. Or if it is, It would be during a very limited time period I guess (when all the bandwith is needed/used…).
But how can you make firewall rules with the same wan/lan interface ? By using network/ip in src or dst instead of etherXYZ ?
Port 1 = WAN - PVID 100 (so access port on vlan 100)
Port 2 = LAN - PVID 200 (access port on vlan 200)
Port 3 or 4 = Router, Trunk port with tagged 100 and 200 VLAN
Making sure bridge vlan filter is on to ensure adherence to the tags and PVID.
On Router you have 1 physical interface, you create a VLAN 100 and a VLAN 200 interface on that physical interface, you then tag VLAN 100 as WAN and VLAN 200 as LAN, this gives you separate interfaces for WAN/LAN. Treat those 2 interfaces like you would physical WAN/LAN interfaces, only difference is they are virtual, but still reach final destination.
It should not reduce downstream or upstream performance too much, depending on your use case. However, if you are big enough to saturate 10gbit links and worry about the excess usage, you are well beyond $400/500 routers and should be looking at higher grade with multiple SFP+ ports (1036 for example)
And I’m not big enough, so when the time comes, I’ll try that, if “next gen” products doesn’t provide 2*sfp+ or 10gbe ports on the 400-500€ range by then.
Saturating 1gb is pretty easy in my case. Now, 10gb, I don’t know, it would depend of the servers I’m using, the peering quality of my isp, etc… (and yes, my LAN is already @10gb). But I’m not there yet
I’m thinking more and more about this since in France the isp Free is pushing 10gb (well, in some areas.
What I don’t understand about router on a stick is the bandwith impact. Port are full duplex nowadays, so, If i launch a download and can get 10gb/s… wan-vlan=>10gb router port receiving at 10gb =>cpu doing firewall, routing, etc => same port sending at 10gb =>lan-vlan. In theory, I can have a 10gb download speed… right ? (I’m not considering cpu perfomances here).
If I’m right, my only limitation would be that I can’t have symetrical full speed, like downloading and uploading at 10gb at the same time, whick would never occures anyway. Am I right about this ?
And btw, do we know the limitation of tile cpus in this setup ? With fast path, I believe ipv4 will be fine, but I wonder about ipv6…
