hi guys
here is the speed graph taken from my 4km link with no nstreme enabled…
not sure why nstreme doesn’t work on my link.
anyhow the speed is going up and down and is not what I’m expecting for -75dbm…
any idea how to fix it will help me alot
2 R name="Public AP" mtu=1450 mac-address=00:0B:6B:37:B0:57 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name="Athenaeum" mode=ap-bridge ssid="PersiaSYS" area=""
frequency-mode=regulatory-domain country=no_country_set antenna-gain=0
frequency=2462 band=2.4ghz-b/g scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=static wds-default-bridge=bridge1
wds-ignore-ssid=yes update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=yes
[/img]
Hellbound:
hi guys
54Mbps
compression=yes
[/img]
Have you tryed to upgrade to 2.9.12?
Regards
already tried but it didn’t help any and it was abit slow on my pc (don’t know why)
Slow?? :S, try only B or only G… and set basic rates at lowest you can
Regards
Do you suggest that lowering basic rates improves constant performance?
tully
February 17, 2006, 8:01pm
7
We are going to have to remove the basic-rate setting as it is making allot of headaches for us and others. The only time you can enable higher basic rates is when you have a perfect connection and it won’t speed things up so much that you can see a difference.
John
