Can I reduce 400mw atheros to 65-100mw and add 1watt amplifier to it. 400mw does not break through trees. I use 15db Omni antena (hyperlink)
Any suggestions Dudes?
We use a chainsaw.
In south africa we burn the tree down
both applies for here - Bulgaria ! :}
I only had once problem with one building but they catch me with the dynamite … ![]()
Yes, yes and yes
good idea, i will build VPN to grandmo with over Pacific Ocean, than need wirelessly to long distance radius..and pinging not more than 1ms…,off course.
What hardware will you use for that?
lol
Why can’t you just put a CM9 card in the AP?
i think it’s better to use sr2 without any amps
regards,
C. G.
Thanks Dude, what are the hardware specifications of SR2
hi,
http://www.ubnt.com
just try, it works ubiquitious…
regards,
C. G.
