2.4 GHz best AP settings
I need best settings for ap on 2.4g. ~max 20 clients peer ap (randomly) Max transfer peer client 512/512kbps. I have B/G cards. The best settings that I managed to achieve :
0 R name=“ap_xxx” mtu=1500 mac-address=00:02:6F:xx:xx:xx arp=enabled disable-running-check=no interface-type=Atheros AR5213 radio-name=“00026Fxxxxxx” mode=ap-bridge
ssid=“xxx” area=“” frequency-mode=manual-txpower country=poland antenna-gain=0 frequency=2447 band=2.4ghz-b scan-list=default rate-set=configured
supported-rates-b=11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=11Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=lan_xxx wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no
security-profile=abp disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00
hw-retries=4 frame-lifetime=0 adaptive-noise-immunity=ap-and-client-mode
What can I change to get the most effective client connection ?
Use RTS/CTS or nestreme if possible. Increase HW retries to 6 or 8, improve poor clients.
where i can set rts/cts ?
^^ I was wondering the same thing. I’ve looked everywhere in the advanced screen for WLAN and nothing with RTS, though I recall seeing somewhere before..
RTS/CTS setting is client side, so it will depend on the CPE.
http://wiki.mikrotik.com/wiki/Wireless#Frame_protection_support_.28RTS.2FCTS.29
