Hi any who has the best way of at least overcoming interference on 2.4 using mikrotik as AP and nanostations as CPE. Any settings one has thought or tried that works best. The environment is very noisy (too many wifi equipment)
enable ANI (ap and client mode) on routerOS AP … use channels 5 or 10 mhz, and if you can work with horizontal polarity, is usually much cleaner than the vertical!. ![]()
regards
i am using 5Mhz but it still the same issue. maybe i try use polarisation
George Midia
sorry the Nanostations do not have the ANI in them
enable it on ros AP… try to change polarization
We’ve found that small pipe bombs strapped to the interfering equipment works wonders ![]()
Joking of course!
