2.4 GHz Network disappears
I have bought an hAP ax3 and configured it as access point following https://tehnoblog.org/mikrotik-router-how-to-convert-hap-or-hap-lite-into-ordinary-switch-or-wireless-access-point-bridge/. I also changed the WLAN to use German frequency (both, 5 and 2.4 GHz). Then I replaced my old Access Point by this one. Unfortunately the 2.4 GHz network disappears all the time, as I can see using my wlan analyzer. the 5 GHz network is there all the time and seems to be stable. Any idea where I can search? Or should I just send the router back?
bests
Sascha
The config has the answer (probably):
/export file=anynameyoulike
Remove serial and any other private information and place in between code tags by using the </> button.
