I want to use MikroTik 2.4 Ghz wireless link for outdoor. is the 2.4 Ghz wireless link is reliable to use in outdoor offshore/onshore for 1 KM LOS distance.
if is reliable what type of MikroTIk 2.4 GHz you will recommend.
With LOS it should work fine. If the offshore is stationary then a grid or yagi should be great. If it is movable like a boat then a sector or Omni would work. Any Mikrotik Router board would work. Make sure you get one with a AP license Level 4 for the shore side.
The best solution would be have a CPE on the remote end and an AP there to rebroadcast.
