2.4 Wireless not working - SOLVED!!
Hi there,
I go myself some new WiFi 6 units.
Router - RB5009UPr+S+
Indoor Wifi - cAP ax Dual Band - cAPGi-5HaxD2HaxD
Indoor Wifi - wAP ax - 5HaxD2HaxD
Outdoor Wifi - NetMetal ax - L23UGSR-5HaxD2HaxD-NM
I have setup the router and the router is doing the CAPsMAN manegement.
I have 2 seperate WiFi configirations, one for 2GHz AX and one for 5Ghz AX with one SSID. I realised some of my equipment is not picking up the WiFi. When I played around to pinpoint where the issue is I see the 2GHz AX is not visible. So if I disable the provision to "activate" / setup the 5GHz AX and I see no SSID. When I activate the 5GHz AX the devices that can see 5G pickup the SSID. So I have narrowed the issue down to the 2GHz. I have played around even more and changed the Band to the various Bands (2GHz AX, 2GHz G,2GHz N) and then the Channel Width (20MHz, 20/40MHz) and the frequency I have expanded to 2300-7300. But I stil cannot see the SSID on any device, when only 2G is activated and 5G is disabled. What am I doing wrong.
Below is the setup of my router current settings:
current scripts of the router set as the CAPsMAN
2025-02-20 08:29:16 by RouterOS 7.17.2
software id = FC9Z-1KWF
model = RB5009UPr+S+
serial number = *******
add name=bridge1
poe-out status: voltage_too_high
set [ find default-name=ether1 ] comment=WAN name="ether1[internet]"
/interface wifi channel
add band=2ghz-ax disabled=no frequency=2412,2432,2472 name="2.4Ghz AX" width=
20mhz
add band=5ghz-ax disabled=no frequency=5130-5850 name="5Ghz AX" width=
20/40/80mhz
/interface wifi datapath
add bridge=bridge1 disabled=no name=datapath1
/interface wifi security
add authentication-types=wpa2-psk disabled=no name=secKoekWiFi
/interface wifi configuration
add channel="2.4Ghz AX" country="South Africa" datapath=datapath1 disabled=no
manager=capsman mode=ap name=cfg_WiFi2GHz_AX security=secKoekWiFi ssid=
KoekiesWiFi
add channel="5Ghz AX" country="South Africa" datapath=datapath1 disabled=no
mode=ap name=cfg_WiFi5GHz_AX security=secKoekWiFi security.connect-group=
"" ssid=KoekiesWiFi
add name=dhcp_pool0 ranges=192.168.11.100-192.168.11.199
add address-pool=dhcp_pool0 interface=bridge1 lease-time=8h name=dhcp1
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=sfp-sfpplus1
set udp-timeout=10s
/interface ovpn-server server
add mac-address=::::: name=ovpn-server1
/interface wifi capsman
set ca-certificate=none certificate=auto enabled=yes interfaces=all
package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=
cfg_WiFi5GHz_AX name-format="%I - 5gAX-wifi" supported-bands=5ghz-ax
cfg_WiFi2GHz_AX name-format="%I - 2gAX-wifi" supported-bands=2ghz-ax
add address=192.168.11.1/24 comment="LAN IP" interface=bridge1 network=
192.168.11.0
/ip dhcp-client
add comment="Internet WAN" interface="ether1[internet]"
add address=192.168.11.0/24 gateway=192.168.11.1
add action=fasttrack-connection chain=forward connection-state=
established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related
add action=drop chain=forward connection-nat-state="" connection-state=
invalid
add action=drop chain=forward connection-mark="" connection-nat-state=!dstnat
connection-state=new in-interface="ether1[internet]"
add action=masquerade chain=srcnat comment="Internet Connection Rule"
out-interface="ether1[internet]"
/ip ipsec profile
/ip kid-control
add name=Mariska
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name="MikroTik Router"
/system note
set show-at-login=no
Below is my current settings of one of my AP's
2025-02-19 13:37:26 by RouterOS 7.17.2
software id = WWE0-FFJ0
model = cAPGi-5HaxD2HaxD
add name=bridge1
/interface wifi
managed by CAPsMAN 192.168.11.1, traffic processing on CAP
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap
disabled=no
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap
disabled=no
add bridge=bridge1 interface=wifi1
add bridge=bridge1 interface=wifi2
/interface wifi cap
set caps-man-addresses=192.168.11.1 enabled=yes
set enabled=yes interfaces=bridge1 package-path="" require-peer-certificate=
add address=192.168.11.41/24 interface=bridge1 network=192.168.11.0
/ip dhcp-client
add interface=bridge1
/system clock
/system identity
set name="WiFi Kantoor"
/system note
You need to remove
add channel=“2.4Ghz AX” country=“South Africa” datapath=datapath1 disabled=no manager=capsman mode=ap name=cfg_WiFi2GHz_AX security=secKoekWiFi ssid=KoekiesWiFi
Thank you, this worked. I did not know that setting will cause it not to work
