2,4Ghz and 5,8Ghz WLAN in one Routerboard
Need some help support please.
Is it possible to connect 2.4Ghz and 5.8Ghz WLAN Card on one routerboard RH433 and do communications together on one network ?
sure - put a 2.4Ghz card and a 5.8Ghz card in your routerboard running in ap-bridge mode.
Add both Wifi interfaces and LAN port(s) to a bridge interface.
traffic on any interface will have connectivity to any other interface
I make a dubble topics ai… my mistake. i am new here.
Thanks you vk7zms
I think i must put 2,4Ghz on Bridge1 with WDS on Bridge1 and ether1 on Bridge1 with his IP address
then 5,8Ghz on Bridge2 with WDS on Bridge2 and Ether2 on Bridge2 with his IP Address
So
2,4Ghz – WDS ON Bridge1 SSID: 24WLAN
Bridge1 : Port: Bridge1 on WLAN1
Bridge1 on Ether1
IP Address: Bridge1 – 192.168.1.XXX
5,8Ghz – WDS on Bridge2 SSID: 58WLAN
Bridge2 : Port: Bridge2 on WLAN2
Bridge2 on Ether2
IP Address: Bridge2 – 192.168.2.XXX
Is this Setup right ?
sure - you can do that - but I thought you were trying to get them all on the one network? What are you actually trying to accomplish?
