A have a very wired issue with Mikrotik routers from title on 2.4ghz frequency were all my home lights and sensors are connected. First i was using the Routerboard 962UiGS-5HacT2HnT, but because there were lot of moments when my lights start to not respond to commands or to respond with a few seconds delay i decide to return it. At that moment i was sure the router is faulty because i have also two cheap Tenda and TP-link routers that work with same network devices for months with absolutely no delays. This week i decide to buy an hAP ac^2 and i was very surprised to see that this one have identical issues with the previews model that is totally different hardware. In order to isolate the issue i made following things:
- remove one wifi device at a time until i can isolate if there is one wifi light/sensor that can cause issues
- run just with default webfig config to avoid any bad parameters
- avoid router PoE (normally is PoE powered)
- disconnect devices one by one when transmission latency start to be big in order to see if one device cause interferences
- power off all zigbee devices.
- tried RC firmware releases
- change wifi channel to avoid interference from neighbors (just 2)
None on these give me a clue what else can be wrong except one very wired behavior when i disconnect one device from the network (random) the ping replies between devices start to be very big and this can be saw in the middle of the following output when i disconnect two wifi lights:
64 bytes from 192.168.88.1: icmp_seq=263 ttl=64 time=839 ms
64 bytes from 192.168.88.1: icmp_seq=264 ttl=64 time=581 ms
64 bytes from 192.168.88.1: icmp_seq=265 ttl=64 time=3.66 ms
64 bytes from 192.168.88.1: icmp_seq=266 ttl=64 time=2.51 ms
64 bytes from 192.168.88.1: icmp_seq=267 ttl=64 time=2.66 ms
64 bytes from 192.168.88.1: icmp_seq=268 ttl=64 time=1.10 ms
64 bytes from 192.168.88.1: icmp_seq=269 ttl=64 time=0.963 ms
64 bytes from 192.168.88.1: icmp_seq=270 ttl=64 time=199 ms
64 bytes from 192.168.88.1: icmp_seq=271 ttl=64 time=1005 ms #### first light disconnected here, second one about 10 replies later
64 bytes from 192.168.88.1: icmp_seq=272 ttl=64 time=3.23 ms
64 bytes from 192.168.88.1: icmp_seq=273 ttl=64 time=1926 ms
64 bytes from 192.168.88.1: icmp_seq=274 ttl=64 time=986 ms
64 bytes from 192.168.88.1: icmp_seq=275 ttl=64 time=615 ms
64 bytes from 192.168.88.1: icmp_seq=276 ttl=64 time=3699 ms
64 bytes from 192.168.88.1: icmp_seq=277 ttl=64 time=2692 ms
64 bytes from 192.168.88.1: icmp_seq=278 ttl=64 time=1668 ms
64 bytes from 192.168.88.1: icmp_seq=279 ttl=64 time=644 ms
64 bytes from 192.168.88.1: icmp_seq=280 ttl=64 time=434 ms
64 bytes from 192.168.88.1: icmp_seq=281 ttl=64 time=977 ms
64 bytes from 192.168.88.1: icmp_seq=282 ttl=64 time=597 ms
64 bytes from 192.168.88.1: icmp_seq=283 ttl=64 time=1435 ms
64 bytes from 192.168.88.1: icmp_seq=284 ttl=64 time=1700 ms
64 bytes from 192.168.88.1: icmp_seq=285 ttl=64 time=1779 ms
64 bytes from 192.168.88.1: icmp_seq=286 ttl=64 time=920 ms
64 bytes from 192.168.88.1: icmp_seq=287 ttl=64 time=176 ms
64 bytes from 192.168.88.1: icmp_seq=288 ttl=64 time=556 ms
64 bytes from 192.168.88.1: icmp_seq=289 ttl=64 time=379 ms
64 bytes from 192.168.88.1: icmp_seq=290 ttl=64 time=1741 ms
64 bytes from 192.168.88.1: icmp_seq=291 ttl=64 time=940 ms
64 bytes from 192.168.88.1: icmp_seq=292 ttl=64 time=269 ms
64 bytes from 192.168.88.1: icmp_seq=293 ttl=64 time=237 ms
64 bytes from 192.168.88.1: icmp_seq=294 ttl=64 time=613 ms
64 bytes from 192.168.88.1: icmp_seq=295 ttl=64 time=1769 ms
64 bytes from 192.168.88.1: icmp_seq=296 ttl=64 time=1211 ms
64 bytes from 192.168.88.1: icmp_seq=298 ttl=64 time=12188 ms
64 bytes from 192.168.88.1: icmp_seq=299 ttl=64 time=11182 ms
64 bytes from 192.168.88.1: icmp_seq=300 ttl=64 time=10158 ms
64 bytes from 192.168.88.1: icmp_seq=301 ttl=64 time=9134 ms
64 bytes from 192.168.88.1: icmp_seq=302 ttl=64 time=8110 ms
64 bytes from 192.168.88.1: icmp_seq=303 ttl=64 time=7086 ms
64 bytes from 192.168.88.1: icmp_seq=304 ttl=64 time=6062 ms
64 bytes from 192.168.88.1: icmp_seq=305 ttl=64 time=5038 ms
64 bytes from 192.168.88.1: icmp_seq=306 ttl=64 time=4014 ms
64 bytes from 192.168.88.1: icmp_seq=307 ttl=64 time=2990 ms
64 bytes from 192.168.88.1: icmp_seq=308 ttl=64 time=3116 ms
64 bytes from 192.168.88.1: icmp_seq=309 ttl=64 time=2091 ms
64 bytes from 192.168.88.1: icmp_seq=310 ttl=64 time=1092 ms
64 bytes from 192.168.88.1: icmp_seq=311 ttl=64 time=665 ms
64 bytes from 192.168.88.1: icmp_seq=312 ttl=64 time=656 ms
64 bytes from 192.168.88.1: icmp_seq=313 ttl=64 time=1649 ms
64 bytes from 192.168.88.1: icmp_seq=314 ttl=64 time=1709 ms
64 bytes from 192.168.88.1: icmp_seq=315 ttl=64 time=1393 ms
64 bytes from 192.168.88.1: icmp_seq=316 ttl=64 time=2733 ms
64 bytes from 192.168.88.1: icmp_seq=317 ttl=64 time=3214 ms
64 bytes from 192.168.88.1: icmp_seq=318 ttl=64 time=2183 ms
64 bytes from 192.168.88.1: icmp_seq=319 ttl=64 time=1866 ms
64 bytes from 192.168.88.1: icmp_seq=320 ttl=64 time=849 ms
64 bytes from 192.168.88.1: icmp_seq=321 ttl=64 time=1402 ms
64 bytes from 192.168.88.1: icmp_seq=322 ttl=64 time=1109 ms
64 bytes from 192.168.88.1: icmp_seq=323 ttl=64 time=662 ms
64 bytes from 192.168.88.1: icmp_seq=324 ttl=64 time=2814 ms
64 bytes from 192.168.88.1: icmp_seq=325 ttl=64 time=2752 ms
64 bytes from 192.168.88.1: icmp_seq=326 ttl=64 time=1729 ms
64 bytes from 192.168.88.1: icmp_seq=327 ttl=64 time=729 ms
64 bytes from 192.168.88.1: icmp_seq=328 ttl=64 time=3656 ms
64 bytes from 192.168.88.1: icmp_seq=329 ttl=64 time=5473 ms
64 bytes from 192.168.88.1: icmp_seq=330 ttl=64 time=4450 ms
64 bytes from 192.168.88.1: icmp_seq=331 ttl=64 time=3425 ms
64 bytes from 192.168.88.1: icmp_seq=332 ttl=64 time=5189 ms
64 bytes from 192.168.88.1: icmp_seq=333 ttl=64 time=4173 ms
64 bytes from 192.168.88.1: icmp_seq=334 ttl=64 time=3149 ms
64 bytes from 192.168.88.1: icmp_seq=335 ttl=64 time=2149 ms
64 bytes from 192.168.88.1: icmp_seq=336 ttl=64 time=5433 ms
64 bytes from 192.168.88.1: icmp_seq=337 ttl=64 time=4409 ms
64 bytes from 192.168.88.1: icmp_seq=341 ttl=64 time=4688 ms
64 bytes from 192.168.88.1: icmp_seq=342 ttl=64 time=3687 ms
64 bytes from 192.168.88.1: icmp_seq=343 ttl=64 time=7856 ms
64 bytes from 192.168.88.1: icmp_seq=344 ttl=64 time=6832 ms
64 bytes from 192.168.88.1: icmp_seq=345 ttl=64 time=5808 ms
64 bytes from 192.168.88.1: icmp_seq=346 ttl=64 time=4808 ms
64 bytes from 192.168.88.1: icmp_seq=347 ttl=64 time=3792 ms
64 bytes from 192.168.88.1: icmp_seq=348 ttl=64 time=2768 ms
64 bytes from 192.168.88.1: icmp_seq=349 ttl=64 time=1744 ms
64 bytes from 192.168.88.1: icmp_seq=350 ttl=64 time=3579 ms
64 bytes from 192.168.88.1: icmp_seq=351 ttl=64 time=2579 ms
64 bytes from 192.168.88.1: icmp_seq=352 ttl=64 time=2383 ms
64 bytes from 192.168.88.1: icmp_seq=353 ttl=64 time=1359 ms
64 bytes from 192.168.88.1: icmp_seq=354 ttl=64 time=359 ms
64 bytes from 192.168.88.1: icmp_seq=355 ttl=64 time=5636 ms
64 bytes from 192.168.88.1: icmp_seq=356 ttl=64 time=4629 ms
64 bytes from 192.168.88.1: icmp_seq=357 ttl=64 time=3606 ms
64 bytes from 192.168.88.1: icmp_seq=358 ttl=64 time=4009 ms
64 bytes from 192.168.88.1: icmp_seq=359 ttl=64 time=2986 ms
64 bytes from 192.168.88.1: icmp_seq=360 ttl=64 time=1962 ms
64 bytes from 192.168.88.1: icmp_seq=361 ttl=64 time=4715 ms
64 bytes from 192.168.88.1: icmp_seq=362 ttl=64 time=3715 ms
64 bytes from 192.168.88.1: icmp_seq=363 ttl=64 time=4130 ms
64 bytes from 192.168.88.1: icmp_seq=364 ttl=64 time=3106 ms
64 bytes from 192.168.88.1: icmp_seq=365 ttl=64 time=2082 ms
64 bytes from 192.168.88.1: icmp_seq=366 ttl=64 time=2045 ms
64 bytes from 192.168.88.1: icmp_seq=367 ttl=64 time=1030 ms
64 bytes from 192.168.88.1: icmp_seq=368 ttl=64 time=1466 ms
64 bytes from 192.168.88.1: icmp_seq=369 ttl=64 time=1295 ms
64 bytes from 192.168.88.1: icmp_seq=370 ttl=64 time=294 ms
64 bytes from 192.168.88.1: icmp_seq=371 ttl=64 time=1827 ms
64 bytes from 192.168.88.1: icmp_seq=372 ttl=64 time=809 ms
64 bytes from 192.168.88.1: icmp_seq=373 ttl=64 time=4092 ms
64 bytes from 192.168.88.1: icmp_seq=374 ttl=64 time=3076 ms
64 bytes from 192.168.88.1: icmp_seq=375 ttl=64 time=2052 ms
64 bytes from 192.168.88.1: icmp_seq=376 ttl=64 time=2282 ms
64 bytes from 192.168.88.1: icmp_seq=377 ttl=64 time=1258 ms
64 bytes from 192.168.88.1: icmp_seq=378 ttl=64 time=3160 ms
64 bytes from 192.168.88.1: icmp_seq=379 ttl=64 time=4455 ms
64 bytes from 192.168.88.1: icmp_seq=380 ttl=64 time=3450 ms
64 bytes from 192.168.88.1: icmp_seq=381 ttl=64 time=2427 ms
64 bytes from 192.168.88.1: icmp_seq=382 ttl=64 time=4291 ms
64 bytes from 192.168.88.1: icmp_seq=383 ttl=64 time=3276 ms
64 bytes from 192.168.88.1: icmp_seq=384 ttl=64 time=2275 ms
64 bytes from 192.168.88.1: icmp_seq=385 ttl=64 time=2935 ms
64 bytes from 192.168.88.1: icmp_seq=386 ttl=64 time=1911 ms
64 bytes from 192.168.88.1: icmp_seq=387 ttl=64 time=1540 ms
64 bytes from 192.168.88.1: icmp_seq=388 ttl=64 time=1145 ms
64 bytes from 192.168.88.1: icmp_seq=389 ttl=64 time=481 ms
64 bytes from 192.168.88.1: icmp_seq=390 ttl=64 time=374 ms
64 bytes from 192.168.88.1: icmp_seq=391 ttl=64 time=1299 ms
64 bytes from 192.168.88.1: icmp_seq=392 ttl=64 time=288 ms
64 bytes from 192.168.88.1: icmp_seq=393 ttl=64 time=66.9 ms
64 bytes from 192.168.88.1: icmp_seq=394 ttl=64 time=88.8 ms
64 bytes from 192.168.88.1: icmp_seq=395 ttl=64 time=2.09 ms
64 bytes from 192.168.88.1: icmp_seq=396 ttl=64 time=2.19 ms
64 bytes from 192.168.88.1: icmp_seq=397 ttl=64 time=2.04 ms
64 bytes from 192.168.88.1: icmp_seq=398 ttl=64 time=11.8 ms
64 bytes from 192.168.88.1: icmp_seq=399 ttl=64 time=483 ms
64 bytes from 192.168.88.1: icmp_seq=400 ttl=64 time=2.05 ms
64 bytes from 192.168.88.1: icmp_seq=401 ttl=64 time=2.03 ms
64 bytes from 192.168.88.1: icmp_seq=402 ttl=64 time=0.940 ms
64 bytes from 192.168.88.1: icmp_seq=403 ttl=64 time=2.60 ms
64 bytes from 192.168.88.1: icmp_seq=404 ttl=64 time=2.39 ms
64 bytes from 192.168.88.1: icmp_seq=405 ttl=64 time=978 ms
64 bytes from 192.168.88.1: icmp_seq=406 ttl=64 time=0.825 ms
64 bytes from 192.168.88.1: icmp_seq=407 ttl=64 time=1.41 ms
64 bytes from 192.168.88.1: icmp_seq=408 ttl=64 time=4.01 ms
64 bytes from 192.168.88.1: icmp_seq=409 ttl=64 time=384 ms
64 bytes from 192.168.88.1: icmp_seq=410 ttl=64 time=130 ms
64 bytes from 192.168.88.1: icmp_seq=411 ttl=64 time=449 ms
64 bytes from 192.168.88.1: icmp_seq=412 ttl=64 time=0.822 ms
64 bytes from 192.168.88.1: icmp_seq=413 ttl=64 time=1.96 ms
64 bytes from 192.168.88.1: icmp_seq=414 ttl=64 time=2.28 ms
64 bytes from 192.168.88.1: icmp_seq=415 ttl=64 time=1.12 ms
64 bytes from 192.168.88.1: icmp_seq=416 ttl=64 time=0.944 ms
64 bytes from 192.168.88.1: icmp_seq=417 ttl=64 time=1.10 ms
64 bytes from 192.168.88.1: icmp_seq=418 ttl=64 time=2.30 ms
64 bytes from 192.168.88.1: icmp_seq=419 ttl=64 time=1.04 ms
With Tenda and TP-link routers i have stable ping with all devices (~2ms) and when i disconnect one device i did not saw any increase of latency. Any help will be appreciated as i lose lot of time trying to fix this problem.
Thanks,
Marius.
