Hi, have problems with 2.4Ghz snooper. When i try to snoop network on 2.4Ghz, AP reboots. ![]()
RouterOS version, installed packages?
system package print
- Flags: X - disabled
NAME VERSION SCHEDULED
0 system 4.3
1 dhcp 4.3
2 mpls 4.3
3 ppp 4.3
4 routing 4.3
5 routeros-mipsbe 4.3
6 routerboard 4.3
7 security 4.3
8 hotspot 4.3
9 wireless 4.3
10 X ipv6 4.3
11 advanced-tools 4.3
Board RB433AH fresh - running few weeks
what model of wireless card do you have? you should make a supout.rif file after reboot and send to support
Ok. Two R52 (2.4 & 5Ghz AP) R5H WDS
my bad, sorry. I get disconnected not reboot. And i get disconnect cauz i’m connected to AP using 2.4Ghz. And when i try to snoop it disconnects all clients connected to it.
