Use wireless scanner (go to wireless interface, there is a button there to do this) to see how many other radios are sending out on that 2.4GHz band.
The more you see on the frequency you use, the less throughput you will have.
Highly likely you are not the only one.
On 5GHz chances are higher you will be “alone” (so no interference, hence better throughput).
