From the PDF:
print - shows all information that's accessible from particular command level. Thus, /system clock
print shows system date and time, /ip route print shows all routes etc. If there's a list of items in
current level and they are not read-only, i.e. you can change/remove them (example of read-only
item list is /system history, which shows history of executed actions), then print command also
assigns numbers that are used by all commands that operate with items in this list. - applicable only
to lists of items. The action is performed with all items in this list in the same order in which they
are given. - forces the print command to use tabular output form - specifies what parameters to
include in printout - forces the print command to use property=value output form - shows the
number of items - prints the contents of the specific submenu into a file. This file will be available
in the router's ftp - shows the output from the print command for every interval seconds - prints the
oid value, which is useful for SNMP - prints the output without paging, to see printed output which
does not fit in the screen, use [Shift]+[PgUp] key combination
The actual parameters needed to do things like ‘without-paging’ and such aren’t included in the PDF.
Proper readout, from the online documentation:
print - shows all information that's accessible from particular command level. Thus, /system clock print shows system date and time, /ip route print shows all routes etc. If there's a list of items in current level and they are not read-only, i.e. you can change/remove them (example of read-only item list is /system history, which shows history of executed actions), then print command also assigns numbers that are used by all commands that operate with items in this list.
Input Parameters
from - applicable only to lists of items. The action is performed with all items in this list in the same order in which they are given.
brief - forces the print command to use tabular output form
column - specifies what parameters to include in printout
detail - forces the print command to use property=value output form
count-only - shows the number of items
file - prints the contents of the specific submenu into a file. This file will be available in the router's ftp
interval - shows the output from the print command for every interval seconds
oid - prints the oid value, which is useful for SNMP
without-paging - prints the output without paging, to see printed output which does not fit in the screen, use [Shift]+[PgUp] key combination
I’m viewing the documentation PDF in Preview on Mac OS 10.4.1
-=Russ=-
