2.8 to 2.9
mine mikrotik this in version 2.8.10 I can low Packages 2.9.17 and install?
Yes you can upgrade to 2.9 just make sure that the upgrade licence it´s not expired
Regards
Check it in ‘/system license’, do not forget information about upgrading from 2.8 to 2.9 in download site.
Just a question: What’s wrong with routeros-x86 for updating from 2.8 or older to 2.9? Strange effects like spontaneous reboots, missing features or just “you can become unexpected problems with feature x”?
To reverse such a wrong upgrade is just uploading all needed (single) packages (maybe of the same version as installed)?
insel
I suppose,
that only ‘system’ package will be reverted back after upgrade from 2.8 to 2.9, when using ‘router-x86’ package.
