gyus, questions are:
Significantly improved Nstreme performance
how much is nstreme improved compared to v2.8.28 ? What about nstreme2 and is anyone successfully running 2.9.1 with atheros HARDWARE COMPRESSION ?
thnx, mp3turbo.
thnx, mp3turbo.
2.9.1 + nstreme uses 100% cpu
which CPU? Routerboard or p4/3GHz ?
Both, tested on a link using pc + routeboard
on 10km link with 700mhz celeron tcp-test show 39-41 mbit (-60 dbm, 36mb fixed) with nstreme and 2560 frame size fixed
and 28-31 mbit with nstreme and compression enabled.
thanks martini, how is it possible that there is just so small portion of people here that can provide real answers?? I will perform extensive testing next Monday and Tuesday, I guess around 6 hours will be devoted to hardware compression tests (2.9.1, 2.9.2 versions) and nstreme2.
