Is it worth upgrading a bgp based router to 2.9.1 from 2.8.28 yet.
Standard Routing and BGP with policy routes. Or is it suggested to hold on the upgrade until 2.9.x is more stable ?
Any comments ?
Any comments ?
Do you have any issues with 2.8.25? if the answer is no or only minor then follow the rule of: If it aint broke don’t fix it!
you have to reconfigure policy-routing rules, in 2.9 they are different.
But 2.9 has new package routing-test, where are added some options and improvements for routing.
