2.9.1
Anyone tried this version? :laughing:
Anyone found the ChangeLog…? :question:
Found it! :sunglasses:
(in the usual place)
Hopefully, as usual, it will fix rather more than is mentioned in the changelog.
I’ll give it a try tonight.
Regards
Andrew
Nothing about Prism cards :frowning:
It fixed a probem I was having where my VPN root router fould jump to 100 % cpu and only a reboot would fix it..
(IP Sec 3Des) 2 remote peers to 1 central router
IE: Rtr1 -----> Rtr2 <-----Rtr3
Now all seems well..
Craig
Fixed my problem with huge counter values on the Filter page.
Maybe we should have an alternative change log :slight_smile:
This has been said before, but MT really need to think seriously about making more information available about changes. This information can’t be that difficult to produce from whatever bug-tracking software they use. For anyone using these devices in a production environment, this sort of information is critical in deciding whether to make the upgrade or not.
Regards
Andrew
But where is the old changelog to v2.8?
