2.9.11 upgrade (532rb)
just did an upgrade from 2.9.8 to 2.9.11 up grade went fine but the like is down (luckily it’s not yet in production) packages shows all the the new files but the wireless test package is grayed out. loaded the wireless package by its self again. now I see the new and old the new is not grayed out but the link stays down.
Any thoughts.
Erik
From the ChangeLog: *) added ability to enable & disable installed packages
You have to configure wirereless-test by CLI
could you tell more detailed information how did the upgrade - what files uploded, did you get any error messages,etc?
I uploaded the complete package. I noticed the link was down so I checked the packages and all “test” packages were grayed out. So I uploaded the wireless package and this timed it showed. I removed the grayed out one.
Digging a bit I found most of my link settings had reverted to default, so most of my setting were wiped out. I will be working on it later today. I hope that wiping out my settings is not normal on an upgrade! I have another link I would like to do but I’m a bit hesitant to mess with a good working link.
On the bright side I noticed that the wireless section in winbox seems to work now, as it show the wireless button and everything I have checked so far comes up, like the narrow channels, etc.
