What's new in 2.9.13:
*) added support for SSH DSA keys;
*) fixed bug - nstreme link with framer-policy=dynamic-size was not
taking into account framer-limit;
*) fixed bug - RADIUS disconnect request did not work;
*) fixed problem - PPPoE server had too aggressive initial timeouts, and
some clients could not connect;
*) improved WPA link establishment for WDS;
*) fixed problem - interface graphs got lost on reboots;
yup, x86, uploaded, rebooted, kernel panic, āattempt to kill initā, used netinstal to rebuild with 2.9.12, uploaded 2.9.13, reboot, now all packages enabled (wireless, w-legacy, routing, routing-test, ā¦). Now going to disable unwanted packagesā¦
Does anyone know why this happens with an upgrade from 2.9.12 to 2.9.13, in a RB532A with 6 ether doughter board.
WARNING: link failed: Invalid cross-device link
installed routeros-rb500-2.9.13
mount: Mounting /root on / failed: Device or resource busy
Restarting system.
This version of routing-test has a very broken OSPF.
OSPF logging does not work
OSPF ādiesā, all routes go missing, and entire platform responds very slowly at least 5 times per day.
Rolled back to 2.9.12 + 2.9.12 routing-test and all is well again.
Not worth sending a supout.rif - its easily replicated.
Why do the change logs never contain everything ? eg:-
Resource graphs from 2.9.12 fixed
OSPF in routing-test modified in some way but weāre not fully sure what we actually did to it
