I’m trying to install version 2.9.14 on a new CF card in a Mini-ITX system. The installation goes fine until it gets to the part that says, “Installation Complete” and then the system just hangs. Rebooting the system hangs after it checks the disks and finds them ok.
Any ideas? Installed it twice with the same results.
Listen to my advice Just TRY with another one. I had some strange situation with a few Kingston cards. Replaced it with some no-name and worked OK.
But, if the installation fails with the second CF, we will discuss further
I’ve also seen some non CF compliant cards (look for the logo) not work like this. Also check to make sure you are using the primary channel of IDE, not secondary or other. You may also want to set BIOS to the exact parameters of the disk instead of using auto detect.
Ok, it wasn’t the flash cards. I’m installing in a Mini-ITX board with a separate PCMCIA/CF adapter that uses a daughter card. When I remove the daughter board, the system boots fine. With the card installed, it hangs.
Any idea why the daughter card would hang the system? This is with nothing plugged into it.
