2.9.18 released ...
What’s new in 2.9.18:
*) fixed bug - dhcp server, dhcp client and hotspot could show up as
invalid in case of many (> 10) vlan interfaces;
*) added back ospf logs, they were removed since 2.9.13;
*) fixed vrrp mac address restoring after reboot;
*) upgraded SysKonnect SK-98xx/SK-95xx Gigabit Ethernet driver;
*) inceased the speed of CDMA modems;
*) fixed netwatch missing ping replies;
*) added ability to reset counters for single queue;
*) fixed bug - PPTP server started to use 100% CPU after NMAPing it;
*) changed behaviour of scheduler entries that have start-time=startup:
use router uptime instead of clock time,
if interval is not 0, then do not run that entry immedeately after startup;
*) added radius-default-domain setting for hotspot server profile;
When did the command
ip address print
stop showing the interface the IP is assigned to? It’s a major hassle to have to do
ip address print interface etherX
for when I’m trying to find where an IP address is.
It didn’t, just make your terminal window a bit wider.
Or do “/ip address print detail”
–Eric
I was actually at the machine itself, not connected remotely. Intererstingly enough, after the machine sat for about 20 minutes I did the ‘ip address print’ command again and this time it gave me the interface information.
