2.9.2 now out - including a few wireless "fixes"
What’s new in 2.9.2:
*) removed “/system scheduler move” command;
*) added “start-time=startup” option for scheduler items;
*) updated PPTP connection tracking driver;
*) fixed wireless registration handling on radar detect event;
*) fixed multiple file uploading in WinBox;
*) improved performance of bridging over WDS when neighbor discovery is
enabled;
*) fixed hotspot to log RADIUS accounting Start and Update request
timeouts as warnings and not errors;
*) fixed problems with PAP authentication in PPP, PPPoE, PPTP and L2TP;
*) fixed GPS;
*) fixed hotspot www servlet to use smaller amount of memory;
*) updated Prism disconnecting to improve reconnect time;
*) fixed Prism STA scanlist handling;
*) improved handling of PPPoE, PPTP and L2TP sessions;
*) added missing server field in hotspot active user list;
*) fixed bug - hotspot did not allow access to its routed hosts from
outside even when address-pool=none;
*) fixed bug - DHCP server could hang in rare cases;
*) fixed bug - hotspot limited addresses-per-mac even if address-pool=none;
*) removed preamble-mode=both for Prism cards;
*) fix WDS statistics counters;
I have update my all AP RB532 and that working fine.
and my other X86 verions working fine to :slight_smile:
And finaly it dont disconect the users on AP anymore !! (beefore is was every 10 sek)
Good work!
//Rickard
