What’s new in 2.9.22:
*) show detected http-proxy for hotspot hosts;
*) fixed webproxy-test to detect http-proxy for hotspot hosts
(broken in 2.9.12);
*) fixed MAC address changing in Ethernet like interfaces
thnx andrewluck
(broken in 2.9.12);
thnx andrewluck
Opinions? Testings?
Anyone test this release?
Thanks!
Alessio
Yes please…
Anyone testing v2.9.22 ? want to put this 1 into our core router… specially with intel Pro 1000/MT
i have found bug with v 2.9.22 and intel pro 1000 gt desktop adapter.all works fine but in winbox interface stats are broken(show wrong information and blink)
With 2.9.20 all works fine
Same here…
Also, the Intel Gbit adapters are still not correctly recognised in System/Resources/PCI
Ok, I just want to checak and see if anyone else is having any issues with 2.9.22 with OSPF, being used as primarily a backup. Everything worked fine with 2.9.20 before, everything looked fine with 2.9.22 and I upgraded some of my routers and everything was good. Upgraded the rest and one feature of OSPF seems to not be working. Also unable to equal cost load balance with OSPF which I would do before. I’m using the exact examples in the manual (page 106 aka page 119, last page of OSPF in the PDF file). And I am no longer able to switch the link by adjusting it’s cost.
Same problem with traffic graphs on Intel Pro 1000 as Alex described.
I builded a new box with a asus p5p800SE and several intel dual gigabit adapter.
Seems thay are not working fine.
They boot ok, but asap I plug two gbit lan inside each intel nic it stops working, the led on the board ges down and I hav only to reboot the router to have the board working again.
Is it experienced by any one else?
Rosairo
all these problems solved in next release
I have problems with wireless scan on 2.4-GHz, can’t see networks. In 2.9.20 it’s OK
mapik, write to support. something’s wrong in your configuration probably. or maybe there simply are no 2.4 devices in your area (is that even possible?)
Hi… I have the same problem also… put dual port intel gigabit card… it get stuck, stop working, I already reboot and still not working… hope this problem solved in the next version
Ohh, sorry, it was problem with radio card
