2.9.23 - improved rb500 ether1 interface stability
The changelog states that 2.9.23 ‘improves’ ether1 interface stability. What was the issue that triggered this improvement and what can the end user expect? Thank you.
if you did not have majour problems with it - don’t expect anything. it fixes a problem
Thanks for the verbose response. Can you advise on what the problem was that 2.9.23 was supposed to fix?
Regards,
Christopher
crashing the router
I have updated a couple of P4-routers with Intel Gbit ethernet. It seems to work ok now, but for some reason the adaptors are not recognized in the hardware list.
We continue to use this version…
