What’s new in 2.9.23:
*) fixed bug - Intel Gigabit ethernet cards did not report current traffic rate
correctly;
*) improved rb500 ether1 interface stability
*) fixed graphing bug - statistics’ values of cpu graphs
correctly;
Hope this version fix the Intel gigabit problem stuck…
I still have problems with ECMP, and masquerading, packets are lost , and i have read inforum that many people have the same problem,please when will be fixed it ?
Create a another topic and paste in your ECMP and NAT configuration
Hi Everyone,
Been noticing that the Queue tree window in winbox is not always working. On one router it will work fine, and on another it will not. First noticed this in i think it was 2.9.20, just thought it was a fluke of some kind, but it worked just fine in previous revisions. It seems to be working, but i never see the window get updated very often. I am using the exact example for equally sharing a connection in the manual. Anyone else seeing this behaviour?
Chris
Is this a recent problem? I haven’t had this problem in v2.9.18-v2.9.20. v2.9.21 was a nasty surprise in performance.
What chipset and what versions do you have? I’d love to hear about the problem.
Has anyone else had a problem whereby any hotspot users (new or old users) are blocked on all ports accept port 80 after the rotuer has been running for 6-12 hours? It works fine again if you reboot. I do not have this problem with my 2.9.18 routers, only with a rb using 2.9.23. Anyone else?
I have problem too with a verison of Intel Gigabit DUAL.
With the single nic everything seems working.
But with dual if I plug two gbit lans the interface goes down, each led shout down and on interface statistic i see 4Gb traffic in each direction.
If one is gbit lan and the second is manually setted up at 100mbps the the board works fine.
I sent supout before and after the problem occurs but no reply yet.
I have several nics of the same series and all have the problem
The P/N is PWLA8492MT
Regards
