2.9.25 and bgp
Dear Mikrotik,
What haven’t you informed us that new shiny version 2.9.25 of routeros supports only one BGP peer? I have today crash becouse I have upgraded router with 4 BGP peers to 2.9.25.
The logs were full of:
09:37:15 system,info router rebooted
09:37:21 route,bgp,info Failed to open TCP connection: Operation now in
progress
09:37:21 route,bgp,info RemoteAddr=193.16.240.140
09:37:21 route,bgp,info RemotePort=179
09:37:21 route,bgp,info Failed to open TCP connection: Bad file descriptor
09:37:21 route,bgp,info RemoteAddr=195.182.218.98
09:37:41 route,bgp,info Failed to open TCP connection: Operation now in
progress
09:37:41 route,bgp,info RemoteAddr=195.182.218.98
09:37:41 route,bgp,info RemotePort=179
09:37:41 route,bgp,info Failed to open TCP connection: Bad file descriptor
09:37:41 route,bgp,info RemoteAddr=193.16.240.140
09:38:01 route,bgp,info Failed to open TCP connection: Operation now in
progress
09:38:01 route,bgp,info RemoteAddr=195.182.218.98
09:38:01 route,bgp,info RemotePort=179
09:38:01 route,bgp,info Failed to open TCP connection: Bad file descriptor
09:38:01 route,bgp,info RemoteAddr=193.16.240.140
I have to disable all BGP peers except one uplink. Now my whole network runs on static routes. Will I ever see new software that is tested?
Gregor
This is a user-to-user forum. If you wish to inform Mikrotik about a bug, please contact support@mikrotik.com with the supout.rif file from the latest version
I wanted other users to be aware of the problem.
Gregor
That error log seems familiar for me, wait… where do I got that from…hmmm
kidding, cheers…
NOTE : same problem here, already send supout.rif, 2.9.25 routing-test much faster, but much error too..
please test the new routing test package:
http://www.mikrotik.com/download/routing-test-2.9.25_new.zip
Yes, this version is much better. Now MAJOR problems were solved.
Details sent to support.
Gregor
Thanks, but no thanks, I will give grzesjan to try it then, lol
I’ve done enough :stuck_out_tongue:
I am also awaiting for this package to be stable
