2.9.28
I like the improvements in is this version!
Few questions.
  1. Can I change the page where the user check his usage? I want to put my own logo there.
  2. I need a place where I can see al the users and sort them by thier usage. At the moment I can only do that under status, active users but then It only shows the users that are active at that moment!
Thanks for incorporating our suggestions!!
Good.. u have started testing already.. I have upgraded to 2.9.28, but i cant log in to my usermanager again with my existing customer accounts.. this is what i get…Error 501: Not Implemented… any thing am doing wrong?
Efosa
Please reboot the router and make the support output file. Send it to support@mikrotik.com
Also please specify what link have you tried to open.
  1. We will think about that.
  2. We will add upload and download fields in the users table.
So now we are forced to have MT Branding on our client side?
Why not just link the ‘logo’ to the /hotspot/img folder
Hi uldis,
Supout file sent to support@mikrotik.com as directed by u.
I await your response.
Hotspot and User Manager is two seperate things, that’s why you can’t just put in that folder.
For now we will not add any layout customization options as it could change a lot. We will add that only when the User Manager will be fully released - it is still in Beta.
I added this to my webpage and the customers can log in directly from there without seeing the Mikrotik logo. It only shows if they have the wrong username or password and when they logout.
This is good enough for me for now!
Wireless Internet Usage (Worcester)
login
password
HTTP 501 Not implemented error
hello nazemg,
Try to use 'http://router_IP/userman instead of usermanager.
Report back if you will have any problems.
That solved the problem Thanks!
I can’t acces these stats from outside my network on a public IP. It keeps redirecting me to the login page without any error.
I can’t see anything in my firewall rules that will block it.
Any suggestions?
also please note about this line
 <input type="hidden" name="subs" value="">
If the value field is empty it means that the usermanager will select the first Subscriber (customer). If you have multiple Subscriber accounts in the Usermanager then you should specify the name in the value field.
Dolf or anyone can explain my where do you locate that html file, cause i dont understand how the final user can reach that html page cause when you open the browser inmediatly the login mikrotik page appear and you need to login first in order to go the any webpage. I mean do i need to redirect the other page ?. Hope that someone understand what im traying to say.
