*) fixed bug - hotspot https login could crash web server;
*) added fragmented packet matcher in firewall;
*) last critical logs get displayed on login in console and telnet;
*) changed wireless response on link loss;
winbox can’t configure fragment matcher properly (winbox glitch)
does the router defragment packets going through the router? if i drop all fragments in firewall, would it still reassemble them before they get dropped?
how does that bit work?
Default ACL on Wlan IFs was set to reject… I could not change it to whatever no matter what…. Always reject! MAC Filtering DEFAULT ON and Reject ALL??? What were you thinking?
As a result I downgraded! To 2.9.2
I bet WISPs will have a great time hoping on their musts and downgrading their routers….
“added multiple ip address support for dns-update;”
This was added to allow round robin ddns updates. We will be offering a inbound load balancing solution here very shortly.
More specifically you can use /tool dns-update address=x.x.x.x,y.y.y.y,z.z.z.z and our ddns system will setup round robin based on what connections you have available.
